Old 08-05-2005, 02:05 PM   #1 (permalink)
Default pop ups
When I connect to the net.
POP UPS saying spyware problems,Search results come up.
Ad-aware personal did not help..........
help..............
Everyone is prone to fear.One who can dominate this fear is brave.
abhra_life is offline
Old 08-05-2005, 02:56 PM   #2 (permalink)
swatkat's Avatar
Which browser and OS are you using? Install Google Toolbar to block popups.
If you get Popups even after installing Google Toolbar, download HijackThis and unzip it to dedicated folder (like C:\HijackThisFolder\hijackthis.exe).
Run it and click the button "Do a System scan and save log file". Copy the entire contents of the log file and post it.
http://swatrant.blogspot.com/
swatkat is offline
Old 08-05-2005, 03:42 PM   #3 (permalink)
TE God
Try firefox dude,
It will solve most of your problems.
Get it here,
http://mozilla.org/products/firefox
anishcool is offline
Old 08-05-2005, 05:06 PM   #4 (permalink)
un
Also Yahoo Tool Bar, with spyware block & popup blocks works well. I had installed it & it succesful blocked popups, Install it from www.yahoo.com[/b]
un is offline
Old 08-05-2005, 08:32 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
scrub your pc with ms antispyware, spybot, spywaredoctor.
install google toolbar. its got one of the best pop-up blockers. yahoo is also good !
if you r comfortable with IE, no need to change your browser. but try to install MAXTHON, an IE based browser. it too has got a great pop-up and ad-blocker !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 09-05-2005, 12:27 PM   #6 (permalink)
Just Do It
Charley's Avatar
Why dont u try Firefox , it has the option of blocking popups and it is much faster for browsing.
Charley is offline
Old 10-05-2005, 12:33 AM   #7 (permalink)
What? Where? How?
escape7's Avatar
if ur using xp, install sp2, ur problem will be solved
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
escape7 is offline
Old 10-05-2005, 03:09 PM   #8 (permalink)
busyanuj's Avatar
alternately, simply download and install Pop-Up Stopper. It will block pop-ups in most of the web browsers.
busyanuj is offline
Old 10-05-2005, 08:14 PM   #9 (permalink)
QA Juggler
saROMan's Avatar
well if ur more of a IE guy..then install adsgone 2004 popupkiller v5.2.1 from Dec2004 Digit CD...it worked great for me.........
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 11-05-2005, 01:20 AM   #10 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Where is the author of this thread?
Read the above replies. I use Google Toolbar and Win XP SP2 Popup Blocker while on IE and Use Firefox otherwise.
navjotjsingh is offline
Old 11-05-2005, 08:51 AM   #11 (permalink)
sujithtom's Avatar
Yahoo toolbar is the solution. Try also getting Microsoft Anti Spyware. They have solved my problems
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
- by tkin
