Old 25-07-2008, 02:54 PM   #1 (permalink)
Default Opening Yahoo directly-reg.
Hi Guys,
Windows XP Home Edition(SP2) and Mozilla Firefox-3.0.1. when I click any links for e-mail addresses on any websites online, it opens Out look Express instead of Yahoo for sending e-mails. Then, I how to make it yahoo as default?
kumarn_2004 is offline
Old 25-07-2008, 03:04 PM   #2 (permalink)
"Aal Izz Well"
Krazzy Warrior's Avatar
Default Re: Opening Yahoo directly-reg.
I think this is not possible.
However wait for some more replies.
http://twitter.com/krazzywarrior
Krazzy Warrior is offline
Old 25-07-2008, 06:37 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
You can use POP mail with outlook and yahoo, if you use the Yahoo Mail Plus package, which is paid. If you want to open a yahoo compose page whenever you click a link, I dont think its possible. You can use an iexplore link with parameters and all, but too much work, since the link is dynamic, and cookies arent stored forever. So you would need to relogin everytime. Also, the email ID you click on wont be sent when you click.
dheeraj_kumar is offline
Old 26-07-2008, 12:26 AM   #4 (permalink)
TooR
alok4best's Avatar
as Dheeraj said, the best you can do is configure ur Outlook with Yahoo account..
I wish !!
alok4best is offline
AMD to Go TO GDDR3 Directly ? indro Reviews 7 13-02-2008 10:51 PM
destop folder is opening automatically while opening My Computer using shortcut vijay_ss2004 Software Q&A 2 09-12-2007 11:11 AM
Best software to covert DVD to VCD directly clifford Software Q&A 14 19-08-2007 01:11 AM
Installing Windows xp pro directly? thecyclone2k Software Q&A 5 31-03-2005 12:46 AM
install win xp directly deepak_vsoni Software Q&A 6 10-03-2005 11:39 PM
- by tkin
