Old 08-05-2005, 09:38 AM   #1 (permalink)
Chillum Baba
a_medico's Avatar
Default powerdvd delux 6 - direct x problem
when i try to install powerdvd6 delux on my dell inspiron 510m notebook (win xp pro), it says first u need to install direct x 9 of higher...
but direct x 9 have already been installed. i installed it again but it still gives same error.
a_medico is offline
Old 08-05-2005, 10:50 AM   #2 (permalink)
QA Juggler
saROMan's Avatar
bro....go to start->run->dxdiag->Enter
and see what is the ver of ur DirectX .....the 9.0b ver is unstable one...if u have it..switch to 9.0c
you can get it in any Digit CD/DVD
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 08-05-2005, 12:07 PM   #3 (permalink)
best thing will be to remove DX 9 b using DIRECT X ERADICATOR and fresh install DX9c.
medigit is offline
Old 08-05-2005, 03:37 PM   #4 (permalink)
vysakh's Avatar
which version of direct x do you have ?
Incompatible message format
vysakh is offline
Old 09-05-2005, 08:46 AM   #5 (permalink)
Chillum Baba
a_medico's Avatar
thanks mates....that solved the problem
a_medico is offline
- by tkin
