Re: Compatibility???
You can save your impress files as powerpoint files... In general, there are not many problems when you save ppt files in OOo... But I have found minor problems... For example, if you crop/resize pictures within OOo after pasting it in a slide, it usually doesnt come out too well in the presentation...
Otherwise, you can also export as flash, etc...
Arun
