Old 07-05-2005, 05:49 PM   #1 (permalink)
Default video editor
Can anyone suggest a freeware video editing software. I only want to do simple tasks like cutting portions, inserting and rejoining in popular formats, so a small and non-complicated tool will do. Whre can i find it.
thnks to repliers in advance.
manish
Manish
manishji is offline
Old 07-05-2005, 07:49 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
VirtualDub
navjotjsingh is offline
Old 07-05-2005, 09:04 PM   #3 (permalink)
vysakh's Avatar
download virtual dub (most stable version) from here
Incompatible message format
vysakh is offline
Old 08-05-2005, 12:18 AM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm.. I'll suggest you VirtualDub Mod .. It got good additions to VirtualDub itself ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 08-05-2005, 12:15 PM   #5 (permalink)
VCD-CUTTER is also quite gud in these things.
Ashootosh is offline
Old 08-05-2005, 02:00 PM   #6 (permalink)
Is Virtual-dub a full version download or trial?
Hard work never killed anybody..........But why take the RISK
indrajit is offline
Old 08-05-2005, 02:06 PM   #7 (permalink)
Just Do It
I've had this from 2 years but I cant join the files together, why? I contacted Jiao customer care they say it works. It is a great player and plays most of the formats and cuts them too.
Charley is offline
Old 09-05-2005, 12:53 AM   #8 (permalink)
VirtualDub and VirtualDubMod both are free and open source software ... VCD Cutter is a shareware ..
Old 09-05-2005, 11:36 AM   #9 (permalink)
Just Do It
Jiao has another software apart from VCD cutter, its MPEGPlayer which has a registration code wit it. It read almost all known formats. Ive been using it for almost 2 years now.
Charley is offline
Old 10-05-2005, 10:43 AM   #10 (permalink)
Yes VCD-Cutter can join two clips, actually I dont have it now so i cant tell u right now the whole procedure but I'll let u know how to do it as early as possible
Old 10-05-2005, 11:52 PM   #11 (permalink)
try muvee frm ( i think ) last months CHIP
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline
Old 13-05-2005, 06:55 AM   #12 (permalink)
Tux
Posts: n/a
Moviemaker 2 is far better than anything though its a pain to export the file
Old 13-05-2005, 12:28 PM   #13 (permalink)
Just Do It
Yes I know the procedure i.e. press ctrl and select the multiple files you have to join and then then click on join,but when I do that it doesnt seem to work, below the screen it shows that the joined files is 0 bytes. So that does sum up that its not working properly or the software is corrupt.
Someone help me
Charley is offline
Old 17-05-2005, 07:53 PM   #14 (permalink)
which version of vcd cutter u r using rite now.... i think i tried joining clips once n it worked, after that my pc got formatted n now i dont have vcd cutter.
another option 4 u , i think windows xp's movie maker can also join two clips. try it (btw i m not so sure)
Old 17-05-2005, 10:07 PM   #15 (permalink)
No idea bout 'VirtualDub and VirtualDubMod ' But
If you want simplicity then VCD cutter is the one for you.
Also the updated version of 'windows movie maker'
which is shipped with SP2 is quite good n user friendly for editing but im not sure if it can join multiple clips.
But VCD cutter is shareware and the trial version has some features blocked.
Try it n if you like it ya can buy it cos its not very .costly or ya ll have to &@#$# it .
amitsaudy is offline
Old 18-05-2005, 01:36 PM   #16 (permalink)
Just Do It
V3.33 Jiao Mpegplayer.
Charley is offline
