Old 07-05-2005, 04:30 PM   #1 (permalink)
rajat22's Avatar
Default Opera 8.01 Build 7583 Preview 1
is out. You can download and try this beta version.
Release Note:
Unfortunately, a number of users have been experiencing frequent crashes
when clicking links on certain pages since installing Opera 8.0 Final. This build
contains a fix for these crashes. Your feedback about the stability of this
release compared to Opera 8.0 Final is greatly appreciated.
Download it
http://snapshot.opera.com/windows/o801_7583.exe
rajat22 is offline
Old 08-05-2005, 01:00 AM   #2 (permalink)
hcp006sl's Avatar
Default Thanks a lot.
Thank you Rajat. I use Opera. So, I would check the beta version.
Yes, I am finding some problems specially at Wincustomize.com.
Thank you for your information.
Orkut members are invited to join:
http://www.orkut.com/Community.aspx?cmm=28705185
hcp006sl is offline
Old 10-05-2005, 10:49 PM   #3 (permalink)
hcp006sl's Avatar
I am now using it. It's really fast and even better than the previous release.
hcp006sl is offline
