I have a machine with the following config:
Intel 845 GSLV Motherboard
80GB Samsung HDD
256 MB RAM
Samsung DVD Writer
On board graphics
On this machine i have four partitions (C,D,E,F) and D: has windows XP installed on it which i primarily use. On C: I had installed Windows 98 but after some issue i had to format C: resulting in Win98 being removed from my machine. But still at the startup it shows me both Windows XP and 98 and selecting 98 makes the PC go to a dead end (obviously). But this is not my problem. I saw the contents of boot.ini from msconfig and saw two OSes listed one XP as
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /fastdetect
and for another it is written as
C:\"Microsoft Windows" with latter one referring to Windows 98.
Now the problem is that i have one more very old machine with 20GB HDD But the machine is not working any more. That HDD has Windows 98 installed on it is C: and D: of that HDD is almost empty. Now my question is that if i replace all the contents of my 80GB hdd one's C: (after taking a backup) with the contents of the C: from the 20GB HDD then will i be able to boot into Windows 98 on my newer machine. So effectively i will be now having Win 98 on C: and XP on D:
PS: This may be a noob question
