Old 07-05-2005, 12:47 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default powermenu.exe !?
from the digit may cd, i installed several programs including autopatcher.
autopatcher inter-alia, installed 'powertoys'.
but i found that i had also inadvertantly installed a program
called 'powermenu' on my pc. it showed up in the start-up.
so is powermenu (powermenu.exe) connected with powertoys ? or is it a spyware which sneeked in thru some other installation ? however ms anti-spy, adaware, spybot did not identify it as spyware. so shud/can i remove it ?
anyone know ?
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 07-05-2005, 02:36 PM   #2 (permalink)
swatkat's Avatar
PowerMenu is a small tool for enhancing the features of Context menu.
File Info here
http://swatrant.blogspot.com/
swatkat is offline
Old 07-05-2005, 10:54 PM   #3 (permalink)
@swatkat....even i cant understand wtf it means.....
i cant understand the info on the page uv given
futuristically_ancient is offline
Old 08-05-2005, 12:09 AM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm... Powermenu may be added by Autopatcher on your system .. It just adds small tweaks on the windows of programs .. Just right click on any of the Taskbar items and you will see an addition PowerMenu .. Here you can set the Transparency of that window .. set its priority .. and send it to Systray ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 08-05-2005, 01:20 AM   #5 (permalink)
okieeee.......thx for lettin me know bout that @it_waaznt_me
- by tkin
