Old 07-05-2005, 10:51 AM   #1 (permalink)
What? Where? How?
escape7's Avatar
Default help - how to create autorun?
i have put some programs in a cd, i want an html file that would open on inserting the cd which links all the programs together so that they can be installed etc. I know how to make html files, but how do i make it autorun?
need ur help guys
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
escape7 is offline
Old 07-05-2005, 12:01 PM   #2 (permalink)
enoonmai's Avatar
To make your CD autorun, simply create a file called autorun.inf and place it in the CD root. In the file, add these lines:
[autorun]
open=<filename>
icon=filename.ico
where <filename> is the HTML file, say index.html. The third .ico line is not necessary unless you are going to include an Icon for displaying for the CD.
Playing FEAR XP/LSW2
enoonmai is offline
Old 07-05-2005, 01:50 PM   #3 (permalink)
Try digitope visual autorun and cd menu pro editor . both of this lets u to create non html menu pages so u can directly install softwares rather than a message box asking u to download it .
vijaythefool is offline
Old 07-05-2005, 02:39 PM   #4 (permalink)
What? Where? How?
escape7's Avatar
thanks guys, it solved my problem
escape7 is offline
- by tkin
