Originally Posted by smile
Hi.........Everyone
I want to know my network card is showing 10 Mbps ....can i know is it a speed of my network? and what is 10/100 mbps speed. And plzz can anyone tel me how to check my internet speed yes i know what speed connection i have taken ...but where to check the internet speed ?
A connection of 10 Mbps (Mb/s) means that it can transfer data at a maximum rate of 10 mega bits (not bytes) per second. 8 bits = 1 byte, so that's 1.25 Megabytes per second. But there's some "waste" involved for error correction, so the practical data transfer will be limited to about 1 MByte/s.
10/100 Mbps means that your network interface can run at either 10 Mbps or 100 Mbps depending on the rest of the system it is connected to, and on how it is configured. For example, if you use a hub, the speed is limited to 10 Mbps. A network switch can run at 10 or 100 depending on the devices connected to it.
By internet speed, I assume you mean the actual speed of your downloads. That depends on more than one factor such as the website, the quality of your phone line or cable, how busy the server is and so on.
Most ISPs have provision for testing the speed of your connection. For BSNL, go to
http://www.dataone.in/ and click "Check Download Speed".
