Hi
Can anyone help to remove this peculiar folder on my desktop? - It does not have a name.
My system is a Compaq P III 933 Mhz, 128 MB RAM, on Windows ME
It appeared on the desktop after I had to reinstall my OS – Re-installing again does not remove it.
Nothing happens when I select the folder and hits delete, and cant drag it to the recycle bin
On double clicking I get the message – "This file does not have a program associated ……..". Right clicking gives only "open" and "create shortcut" options. Create shortcut gives the message that disk is full and windows cannot create the shortcut.
Anyone has any ideas ?
Thanks,
