i use w2k ....
my machine doesn`t power on/off automatically even though it has an ATX power supply. By default it
should turn on/off automatically.
i have checked all my connections regarding wires & cleaned the dust also ....
have 2 manually start it or shut it down ... which is painfull ....
had deleted some files (dll & exe files)
RSP001.DLL
BHO.DLL
WinStart.exe
BHO001.DLL
ipinsigt.dll
Rsp.dll
WinStart001.EXE
Update_com.DLL
CGJ.exe
msbb.exe
which norton had detected as virus .... has deleting this files created this problem ....
now in system properties my comp is shown as AT/AT compatible ... how can i change it back 2 ATX
compatible ?????
plz can anybody tell me whot the problem is ????
