Old 06-05-2005, 08:12 PM   #1 (permalink)
Default good uninstaller
i have some softwares installed which dont have uninstallers...some dont even show in add/remove progs...or just refuse to get uninstalled.....is there a good uninstalling software available....
thanks in advance
atool is offline
Old 06-05-2005, 09:01 PM   #2 (permalink)
swatkat's Avatar
Try Abosoulte Uninstaller, Uninstallabilty.
http://swatrant.blogspot.com/
swatkat is offline
Old 06-05-2005, 09:41 PM   #3 (permalink)
thanks dear...u r always so helpful
atool is offline
Old 08-05-2005, 02:08 PM   #4 (permalink)
Just Do It
Quarterdeck is also good.
Charley is offline
Old 10-05-2005, 02:23 PM   #5 (permalink)
whoopy_whale's Avatar
System Mechanic Pro contains a software uninstaller.It lets you to remove any application from a PC, even if the application has no uninstaller of its own. Working independently from the Windows Add/Remove Programs function, you can comprehensively search for all associated remnants of a specified program and safely find and remove everything from the system in a single click.
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 10-05-2005, 05:05 PM   #6 (permalink)
thanks for help everyone...
atool is offline
