Old 06-05-2005, 03:56 PM   #1 (permalink)
Default how to conevert 1GB AVI Movie
how to conevert 1GB AVI Movie into 2 CD's can anyone help me out.
\"Let this world be a little better because I came here.
stalin is offline
Old 06-05-2005, 04:12 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Use Easy Video Splitter to split avi into 2.
navjotjsingh is offline
Old 06-05-2005, 04:15 PM   #3 (permalink)
thank's buddy
stalin is offline
Old 06-05-2005, 11:10 PM   #4 (permalink)
umay also use avi2dvd . select the output source as 700mb CD
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline
Old 07-05-2005, 01:11 AM   #5 (permalink)
I got a movie size of 1024 x 786 will the clarity reduce if i convet to movie DAT file
stalin is offline
Old 07-05-2005, 07:13 AM   #6 (permalink)
the DAT file in the vcd uses mpeg-1 4 encoding . mpeg-1 is a ' lossy ' format . so surely the quality is bound 2 go down
i suggest that u make the image files 4 the 2 vcds using avi2dvd . then write 1 of the 2 , on a CD . if the quality is unacceptable , abort mission
mamba is offline
Old 07-05-2005, 09:18 AM   #7 (permalink)
Use Dr. Divx na. It is the best i have ever seen!. U will get what u want for sure.
A student must not fail to become a looser, and when a student fails, he will become a fighter....
Santosh Halemani
Santosh Halemani is offline
Old 07-05-2005, 09:21 AM   #8 (permalink)
NikhilVerma's Avatar
You cannot play 1024x768 format on a VCD player...
I will have to be reduced down to 640x480
NikhilVerma is offline
Old 07-05-2005, 11:13 AM   #9 (permalink)
enoonmai's Avatar
640x480, even that's too much for a TV. Most standard television sets stick to resolutions no greater than 320x240/full color. Clarity loss shouldn't be that much of a problem when transcoding to a lesser quality format. It's usually the other way around that you need to be worried. As long as the transcoding settings are right, quality loss should be pretty low to be considered non-existent.
Playing FEAR XP/LSW2
enoonmai is offline
Old 07-05-2005, 12:10 PM   #10 (permalink)
vysakh's Avatar
enoon, isnt it 352 X 288 ????
Incompatible message format
vysakh is offline
Old 07-05-2005, 12:17 PM   #11 (permalink)
enoonmai's Avatar
Yup, a VideoCD in PAL format is 352 x 288/25fps.
enoonmai is offline
Old 07-05-2005, 11:25 PM   #12 (permalink)
Dr Divx encodes vcdz n dvdz in2 aviz . stalin's query was 2 revert the process
mamba is offline
Old 02-06-2005, 01:30 AM   #13 (permalink)
SABER RIDER
maverickrohan's Avatar
@stalin
check out my siggie topic
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 02-06-2005, 10:08 AM   #14 (permalink)
hey navjot!! .. this easy video splitter didnt worked for me! .. actually i have a movie for 702 MB .. so i just wanted to remove a few seconds movie so tht it can be written on a CD ...
but tht s/w didn't gave me ne splitted file! plzz help me!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 02-06-2005, 10:10 AM   #15 (permalink)
QA Juggler
saROMan's Avatar
well Depends what u want..if u want to view it on Standalone player ..then convert it in VCD format...as told earlier use AVI2DVD ...simply great tool...also the tute for how to use it is given in Digit mag also..
You can also Turn it in to KVCD Format ..to get DVD Quality Print on Single CD...i have used it and Works Great...
if u want to reduce the size then convert it to RMBV format ....i guess 1 Gb will b reduced to 300/400MB ..with out any Significant Quality loss...
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 02-06-2005, 12:01 PM   #16 (permalink)
http://rapidshare.de/files/2122762/_ebook__copy_a_full_dvd_movie_on_one_disk.rar.html
I uploaded it to rapidshare. Download it and read for yoself.
Hibernating ....
banned2wise is offline
Old 02-06-2005, 03:38 PM   #17 (permalink)
SABER RIDER
@meridhaiin
702MB can be easily written on a CD.............for that matter you can easily write upto 710MB....by just enabling Overburn in Nero............!!!
for MORE INFO chk out the topic in my siggie.......
Old 03-06-2005, 01:59 AM   #18 (permalink)
Originally Posted by maverickrohan
@meridhaiin
Well, I know tht ard 703-710 MB can be written to the CD of 700 MB specified! but man! i've this overburn option always there!! but dunno but it is refusing again!
BUT!! guess wat???? today i got one splitter!! named as AVI MPEG Splitter ... it did split tht into 699MB & now it will surely get written on my CD's(700 MB) yeeeeeeeeeeepppppppppiiiiiiiiiiiiii!!!
I'm happy!! but i dunno Y tht silly Easy splitter thing didnt worked!! & ofcourse i did checked ur first post AMAZING!! .... gr8 first post ... sry! for appreciating it late! but plzz accept it! U deserved it! it was helpful!!!
now, as my problem is solved .. i would just wanna know How can i compress my video's using XviD .. can someone help me with tht! tell me the detailed procedure!! plzzz
