Hi,
In my home system win xp proffesional version is installed. Only one account "administrator , with password. But like in my office i did not found any option to lock my pc. (not through log off, i want that ctr+alt+del screen which says "computer is locked and *** or administrator unlock this. From where i can enable this option.
anni
Location: Look below...not under pants dumbo...use a GPS
Re: how to enable 'computer locked ' screen
Goto Control Panel-User Options-then at the top you will see the option "Change the way user Log in or Off" then untick "Use the welcome screen" and you're done !
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Thanks. It works, and win+L works only after this not before changing this option. thanks
