I have an AMD K6-2 on a Jetway J-542B Motherboard system running Windows 98 SE with 128MB RAM, a SiS6215c PCI Graphics Accelerator Card and a Yamaha OPL3 -SAx Soundcard.
a) My motherboards battery has run out. What battery type should I buy to replace it and from which manufacturer? Where can I purchase it from?
b) Recently I removed the soundcard out of it's ISA slot to clean it from dust when I put it back and started my computer, It searched for new hardware and installed it along with a gameport driver. I then removed the gameport driver from the Device Manager and restarted my computer. Windows again installs it. If I select not to the soundcard does not work. This repeats itself if I remove the Gamport driver. Please help.
d) Is there a way to remove buttons I don't use in WMP 7.1 like Skin Chooser, Portable Device?
e) How do I change the Album Name for my CD-Audio in WMP7.1?
f) I want to overclock my CPU and PCI Graphics Card. I use SoftFSB and PowerStrip. What are the correct clock speeds to set it to to achieve optimal performance?
g) Can I install Windows XP Home Edition with my current configuration. How smooth will it run?
megacoolxs signing off .....
