If you've used the IE4 or IE5 image zoom power toy, you might have noticed that it doesn't work as well as it should. You can enlarge an image easily, but when you shrink it again, the image will not retain its proportions. The fix is easy (coding experience not necessary, but strongly recommended). Open the 'zoomin.htm' and 'zoomout.htm' files from 'C:\Windows\Web' and move the 'w =' line directly underneath the 'h =' line, and do the same for the 'parentwin' lines ('h' over 'w'). NOTE: 'zoomin.htm' has asterisks instead of slashes, but you can apply the same tweak.
megacoolxs signing off .....
