Old 14-07-2008, 07:45 AM   #1 (permalink)
Exclamation help vit writing DVD!!!
hi all, i'm using sony disc writer on my p4 machine vit winxp sp2. i've wasted few dvds [4gb] coz of sum problem while writing them [in the initial stage] & lot of space is left on them but nero 8 is unable to burn on dat area of disc.
can any one suggest me a software dat can burn in thos left out parts of the disc...
krp31 is offline
Old 14-07-2008, 08:39 AM   #2 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Default Re: help vit writing DVD!!!
Nero can't burn b'coz u've not left da multi-session on.. If u have kept it on then probably u wer using a different version of nero before. For dis problem use cd/dvd burner provided in digit discs.. They always work for me..
______
If in case u mean thr was a failure in burning discs, then da discs are no more usable..
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 14-07-2008, 02:54 PM   #3 (permalink)
Cool Buddy's Avatar
if the writing stopped due to an error then there is hardly any chance that you will be able to write on them anymore.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 15-07-2008, 06:56 AM   #4 (permalink)
but Sumeet_naik multisession was on but it got aborted due to sum error.
can u plz suggest me d site wher i can download d s/w ur saying!!
krp31 is offline
Old 15-07-2008, 07:15 AM   #5 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Download the trial of Roxio. I guess it may help. If that doesn't work, it might be a problem with the writer. Try to remove the disc writer and plug a new one in. Or add external. If that still doesn't work return to Sony care service
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
Old 16-07-2008, 07:13 AM   #6 (permalink)
i burnt a multisession CD, it did burn perfectly. wht happens to it ven it cums to burning large data [dvd]?????
krp31 is offline
Old 16-07-2008, 07:42 AM   #7 (permalink)
It doesn't matter!
Probably u system runs out of buffer.. Or ur system memory could be low due to other processess..
Wat error does it show at da end?
Old 16-07-2008, 07:46 AM   #8 (permalink)
sorry sumit i dont remember d error msg now. i'v 512 mb ram [1 chip]. i usually hibernate. shld i restart my pc b4 burning disc??
krp31 is offline
Old 16-07-2008, 07:55 AM   #9 (permalink)
It doesn't matter!
Well, u cud try tat too.. But 512mb is sufficient if no background process are running..
Old 16-07-2008, 02:44 PM   #10 (permalink)
Cool Buddy's Avatar
try writing at a lower spped. remember that a spped of 8x for a dvd is faster than 52x for a cd. So try writing at 4x if you had been using higher speeds. Also, generally if writing stops due to errors, the disc becomes useless, generally, not always
Also you shud leave the computer idle while writing is on, no screensavers too.
Nokia 5230 :(
Old 17-07-2008, 06:23 AM   #11 (permalink)
hi cool buddy, thanx for ur concern.
well i'v never had such errors when i would write @ d default speed specified by nero. this problem occurs occasionally & only in case of dvds [not cds].
as u said i dont run any other app other than nero while it is writing.
krp31 is offline
Old 17-07-2008, 04:36 PM   #12 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
& burn till 4.2gb only ...... in 4.5gb dvd ......
... W H O T ...
ax3 is offline
Old 18-07-2008, 07:18 AM   #13 (permalink)
ya ax3, i do take dat precaution too. but nt getting ver i'm going wrong.
krp31 is offline
Old 19-07-2008, 09:25 AM   #14 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Did you try to restart? If it still doesn't work return to Sony Care
Old 19-07-2008, 02:47 PM   #15 (permalink)
The Researcher
may be you should consider changing disc brands. I am using Sony and I have never ever wasted any DVD.
Ramakrishnan is offline
Old 20-07-2008, 06:40 AM   #16 (permalink)
ya i shld try restarting my machine b4 burning dvd. this i had never thot of.
well Ramakrishnan, i dont use any particular brand of discs. its any.
krp31 is offline
Help in DVD writing Hari_04415 Software Q&A 14 07-07-2007 01:15 PM
CD Writing Him007 QnA (read only) 4 15-06-2007 08:48 PM
Writing a CD [A]bu QnA (read only) 8 27-05-2007 11:48 AM
Writing DVD RWs... shyamno Hardware Q&A 13 02-05-2007 12:53 PM
cd writing noblefriend2002 QnA (read only) 2 20-08-2004 06:03 PM
