Old 06-05-2005, 11:32 AM   #1 (permalink)
Default Errrrrrrrror
my computer showing error on windows 98 the error is :
this proogram has performed an illegal operatio and will be shut down
EXPLORER caused a general protection fault
in module USER.EXE at 001b:00000a08.
Registers:
EAX=00000000 CS=16f7 EIP=00000a08 EFLGS=00000246
EBX=015f00f6 SS=42c7 ESP=00008a84 EBP=000024eb
ECX=00000000 DS=16bf ESI=00000000 FS=38c7
EDX=038d0000 ES=0000 EDI=00000000 GS=0000
Bytes at CS:EIP:
c2 0a 00 90 c8 0a 00 00 56 ff 76 10 6a 00 6a 00
Stack dump:
82779090 24eb0040 82779090 14eb0040 82779090 14eb0040 82779090 82770040 90900040 90909090 90909090 90909090 90909090 90909090 90909090 90909090
what should i do?
i am cool
RAVINDRA21 is offline
Old 06-05-2005, 01:27 PM   #2 (permalink)
protection fault generally arises when any of your program tries to access your kernal memory space(restricted because its like the heart of ur OS), since you have not told what application u were running or installed has led to this, it is impossible to sort out your problem.
You dont Understand Something..
DESTROY IT
.... Secret of survival
kiran_k is offline
Old 06-05-2005, 01:38 PM   #3 (permalink)
U have'nt told wat program you were using....
Chiao!
_____
futuristically_ancient is offline
Old 06-05-2005, 02:11 PM   #4 (permalink)
swatkat's Avatar
Do you get this error frequently? Update Internet Explorer to IE 6 SP1, if you havent done it already.
Download here
Also, try reinstalling Audio and Video drivers.
http://swatrant.blogspot.com/
swatkat is offline
Old 07-05-2005, 09:32 AM   #5 (permalink)
Hey I had posted this error before got no result and problem had gone. But, the problem is back and it lies in the windows>minidum. The problem might be with the ram not responding for the os(xp). Recently installed autopatcher march edition. next thing this problem.
A student must not fail to become a looser, and when a student fails, he will become a fighter....
Santosh Halemani
Santosh Halemani is offline
