Old 06-05-2005, 11:01 AM   #1 (permalink)
anomit's Avatar
Default Suspicious registry key
I noticed a suspicious looking registry key:
HKLM/SOFTWARE/MICROSFT/Tracing
What is this supposed to do? Also some weird files like dot.exe are getting installed on my comp when I connect to internet. What are these?
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 06-05-2005, 11:41 AM   #2 (permalink)
I dont know programming but its something related to TraceRegister/TraceDeregister
Lovedeep Wadhwa
cheetah is offline
Old 06-05-2005, 02:25 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
when in doubt, play safe.
a dot.exe file can possibly be associated with AdWare.180Solutions
run a good anivirus like bitdefender, avg, kaspersky or avast.
run a couple of good anti-spywares like microsofts', adaware, spyware doctor or spybot.
run ace utilities or tune-up utilities or ccleaner to clean up your junk files and registry entries.
should take of your problem hopefully !
have a nice day !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 06-05-2005, 02:31 PM   #4 (permalink)
swatkat's Avatar
Hmmm...Another appearance of Dot.exe, first saw it in drgrudge's log, and now here. I think i should inform Pacman's Startup portal again.
More info here
http://swatrant.blogspot.com/
swatkat is offline
Old 06-05-2005, 04:20 PM   #5 (permalink)
go to safe mode and remove the dot.exe file it is some kind of adware or spware. I to got it once.
\"Let this world be a little better because I came here.
stalin is offline
Old 06-05-2005, 09:33 PM   #6 (permalink)
enoonmai's Avatar
There is no information on dot.exe, and its not a known/acknowledged malware/VULN so far. It may just turn out to be a newer virus/malware with a random filename, I would recommend waiting and checking it out before deleting anything. Although, checking out the active connections on the firewall/netstat wouldn't be a bad idea.
Playing FEAR XP/LSW2
enoonmai is offline
