Old 13-07-2008, 04:43 PM   #1 (permalink)
The Boss
aytus's Avatar
Default should I use PORT FORWARDING????
hI!! all
i am using H500 plan on BSNL and ive heard too mch about port forwarding .. so i gave it a try..and went ahead and configured it. but the thing is that there is no change in speeds wheather i use port forwarding or not.
in both cases i get the same speed.. around 110KBps download and 20KBps upload .. i am pretty satisfied with the speeds but the question is should i use port forwarding or not.. i only have a single computer and dont have any other network to fuss with..
so do u suggest i should use port forwarding or not// i dont see any potential advantages in using it.. if anybody else knows any advantage of using it.. tell me .
I am talking about the speeds of Utorrent BTW
and one more thing i want to know.. what does the option of (enable Upnp port mapping ) means in utorrent??
G3N10U5 BY B1RTH, HACK3R BY CH01C3
E5200; Biostar P43-A7; Palit GF 9600GT; Corsair 4GB; CM extreme power 390W
aytus is offline
Old 13-07-2008, 08:21 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: should I use PORT FORWARDING????
well if u are satisfied then who is complaining
btw, they are decent speeds as per ur plans so be happy...
on my 256 connection i get speeds of 210 kbps and d/load of 110 kbps..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
port forwarding? evewin89 QnA (read only) 3 01-03-2008 02:35 PM
port forwarding napster007 Software Q&A 2 01-03-2008 12:31 AM
Port Forwarding thrash_metal Software Q&A 1 03-08-2007 09:04 AM
Port Forwarding.. shyamno Hardware Q&A 3 26-01-2007 10:16 PM
Port forwarding bharat_r QnA (read only) 6 10-07-2005 02:01 AM
