Old 12-07-2008, 06:37 PM   #1 (permalink)
DigitDonz's Avatar
Unhappy 64 bit or 32 bit
Hai Friends, I just installed Windows Server 2008 Enterprise Edition on my system for a trial run, along with Windows XP SP3 and Vista Home Premium, mine is a 32-bit System, XP and Vista Says so.., but Windows Server 2008 says I have a 64 - bit OS i.e.., When I rightclick on Computer and choose properties it says I have 64 bit os, but when I right click on desktop and choose settings it says I have 32-bit.. Why is this happening?
;) Join the new blogging arena on the internet Visit http://www.softwaredonz.co.nr
DigitDonz is offline
Old 12-07-2008, 07:11 PM   #2 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Default Re: 64 bit or 32 bit
When you right-click on the desktop and select settings, the 32-bit being shown is the color depth in use by the display adapter!! You probably have 32-bit editions of XP & Vista whereas the Server 2008 edition might be a 64-bit one!
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 12-07-2008, 08:07 PM   #3 (permalink)
DigitDonz's Avatar
Unhappy Re: 64 bit or 32 bit
is that means I can even install 64 bit Vista and XP on my System, I have heard that 64 bit OS needs special hardware and is costly..,
Old 12-07-2008, 08:11 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
What is you processor ??
To install any 64 bit OS you are in need to have a processor supporting x64 architecture, processors having features like AMD 64 (AMD) / EM64T (Intel) would allow you to install any x64 OSes (Vista / XP / Ubuntu / Fedora / Solaris)
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 12-07-2008, 08:46 PM   #5 (permalink)
DigitDonz's Avatar
Mine is Intel C2D E4500 2.20 Ghz, I think mine won't support 64 bit OS.., But why do Windows Server 2008 says mine is 64 bit OS?
Old 12-07-2008, 10:41 PM   #6 (permalink)
Rebooting
Every single Intel Core 2 processor comes with EM64T hence yes you can run x64 OS under your processor
and I was wrong seems there is one single Core 2 processor, the E4700 2.6 GHz which doesn't come with EM64T... Strange very strange as matter of fact it would cost more for Intel to remove the function
Hey wait a minute...
I found a Typos...
Intel E4700 does come with EM64T where as Core 2 Duo main chart page shows it doesnt
http://www.intel.com/products/proces...t/core2duo.htm
where as the individual page for E4700 do include EM64T with it
http://processorfinder.intel.com/det...px?sSpec=SLALT <= E4700
rebooting
ChotoCheeta.com
Last edited by Choto Cheeta; 12-07-2008 at 10:54 PM. Reason: Automerged Doublepost
Old 13-07-2008, 08:12 AM   #7 (permalink)
DigitDonz's Avatar
Tnx for the link, it seems my processor supports 64-bit OS, so can I go with XP 64 bit edition too, One more doubt If anyone want to go with 64-bit OS, Does he needs only 64-Bit supported Processor..
Old 13-07-2008, 08:45 PM   #8 (permalink)
Yes, you need compatible processor to run run 64bit OS, older processor ( like plain P4) doesn't support 64-bit OS
I've a different doubt though...
Is there any particular advantage of running 64-bit OS part from that fact that it can support more than 4GB RAM and more important will I be able to use same applications on 64 bit OS as I did on 32bit system?
genxguy is offline
