Old 29-08-2004, 11:33 PM   #1 (permalink)
Default app to rip music from flash animations
i wanna extract the music from say...the winXP tour..which app can i use??
rj2k is offline
Old 30-08-2004, 07:33 PM   #2 (permalink)
Capturing the music from the app. would be a lot easier.
If ya wanna extract it then try browsing the app. with resource hacker n see if you find any midi or wav files u can save.
Or it can be that the midi or wav is stored somewhere in ur windows or windows/system.
If ur familiar with decompiling n reversing then its nothing.
Many tutorials are available on the WWW.
amitsaudy is offline
Old 30-08-2004, 08:48 PM   #3 (permalink)
dont use anything as geeky as the resource hacker or something like that
if you are the member of the digit community search for FLASh in the archive , digit has included several softwares for hacking all the stuff from the SWF files , but you will have register first if you want to use them
but they are very goood
Killer_Sam is offline
Old 30-08-2004, 10:42 PM   #4 (permalink)
What community?
How to register?
Old 06-09-2004, 05:49 PM   #5 (permalink)
use SWF DECOMPILER it extrcts everytin used inside any SWF file. google it or pm me with ur mail id for more info and the special link for tis proggie
I tink i am too late here.
jassalmithu is offline
