Old 05-05-2005, 09:27 PM   #1 (permalink)
Default System restore
Hi
How can i remove system restore points.
mako_123 is offline
Old 05-05-2005, 09:51 PM   #2 (permalink)
check this
http://www.microsoft.com/windowsxp/u...emrestore.mspx
\"Let this world be a little better because I came here.
stalin is offline
Old 05-05-2005, 11:15 PM   #3 (permalink)
You have the option to delete all but the latest restore point from your machine or delete all the restore points on your machine. To do this:
To delete all but the latest restore point on your machine by using the disk cleanup utility: Go to 'Start > All Programs > Accessories > System Tools > Disk Cleanup'. Click on the more options tab and then click 'Clean up' in the System Restore box.
To delete all the restore points on your machine disable and re-enable system restore on the system: Go to the Control Panel ('Start > Control Panel') and open the 'System' applet. Click on the 'System Restore' tab on the system applet. Check mark 'turn off system restore on all drives' and click the apply button. Then uncheck the box again to re-enable System Restore on the machine and click OK.
You can also reduce the number of restore points saved on your machine by lowering the total amount of disk space available to system restore. Remember that the lower the disk space available to system restore, the lower the number of restore points that will be available on your machine and smaller the safety net available to you through System Restore.. To do this please see 'How can I adjust how much space System Restore uses on my disk?'
Chiao!
_____
futuristically_ancient is offline
Old 06-05-2005, 02:43 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
a related question.
in case you have several restore poins on your pc, can you SELECTIVELY delete Restore Points, which you dont want ? is there a provision in windowsxp, or is there any utility ????????? 8)
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
