Old 05-05-2005, 08:22 PM   #1 (permalink)
Default problem with mic
I recently bought a headset. The speakers are working fine but when i tried to test the mic using sound recorder on Windows XP ...the mic doesn't seem to work. I tried the same on my friends PC but the mic worked fine there. Another notable issue was that the sliding bar of the sound recorder didn't move forward when i pressed the record button.
Also when i tried the sound recorder on LINUX (gnome-sound-rec) it crashed.
I suspect there is some hardware problem. Any suggestions?? how to solve or detect the problem?
I have an Intel D845GLVA motherboard, no additional sound cards.
surdy is offline
Old 05-05-2005, 08:27 PM   #2 (permalink)
I dont know about ur board. In my Asus is a 7.1 with Line In & Mic.
Asus has automatic jack. That is it can switch the jack to either Mic or Line or some other channel depending upon the device.
But due to driver issue it was having some trouble.
Now solved. Try checking your Manual and the Intel Website.
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 05-05-2005, 11:21 PM   #3 (permalink)
Are u sure u plugged ur mic in the right jack?
There's no problem with ur mic as it is workin fine on ur fren's comp.
To rectify it:
Go to the volume tab (there'll be a speaker icon in the notification area).
Here, go to Options>Advanced Controls
Now, u'll be able to see more tabs.
Simply increase the volume of the "Line In" tab.
If this does'nt rectify ur problem, try finding help in the windows' built-in help feature.
Chiao!
_____
futuristically_ancient is offline
Old 06-05-2005, 12:03 AM   #4 (permalink)
Default thanx pll ..prob solved automatically
i tried everythin i could ...as a last resort i put the query on the forum ....shut down the PC ,,,had dinner ...rebooted and now it works .....
i dunno why
sometimes u just cannot explain things .....
and yes the mic was in the right jack ...i am not that foolish 4 God sake
surdy is offline
