I am unable to install kodak easyshare software on my pc. I tried installing from both
1. the CD that came with my kodak CX7330 digicam
2. Downloading from the web
but it gives me an error
MY PC config is WIN XP Home with SP2, 256 MB RAM, 80 GB HDD.
Is SP2 the culprit? If yes how do I make it work?
can't help u there, but if u use xp u can directly extract the images from ur digicam. I also am not able to install the sofware, so i directly extract the images.
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
Wats the error msg u get?
Btw, u can try d following:
Plug-in the usb cable from ur cam to ur pc. Windows will automatically detect ur cam. Install the default drivers.
After this, try installing the driver that came on the cd.
