Old 09-07-2008, 06:48 PM   #1 (permalink)
raksrules's Avatar
Default SD Card for Canon SX100IS: Sandisk 2GB Normal SD or Extreme III ??
My brother is buying Canon sx100is camera from US. Which SD Card he should go for ?
-> Sandisk normal 2GB Memory Card (approx 15 $)
-> Sandisk Extreme III 2GB Memory Card ?? (approx 35 $)
Is the price difference worth it ? if yes then why ?
raksrules is offline
Old 10-07-2008, 12:52 AM   #2 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Default Re: SD Card for Canon SX100IS: Sandisk 2GB Normal SD or Extreme III ??
Ultra III
Ultra II
Just compare 2 with 3 then then you'll understand the difference b/w 1 & 3
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 10-07-2008, 01:04 AM   #3 (permalink)
dOm1naTOr's Avatar
its the assorted write speeds thats differs much and no one wud ever write dat much data into a card for a digicam. The read speeds aren't that much to boast for the Extreme III, not even double. SO i think the normal one is enuf.
But if its meant for a phone or a PMP that supports card, then write speed really helps, in transferring the music and videos.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 10-07-2008, 08:32 AM   #4 (permalink)
gopz's Avatar
The normal one is enough. But if you do a lot of video, then I suggest the $35 one, because it will write faster.
OT: Why dont you ask him to check out Nikon P80 and Olympus SP-570uz too, they offer great VFM.
gopz is offline
Old 10-07-2008, 02:14 PM   #5 (permalink)
Others have raised valid points regarding the difference between the two cards, so I won't repeat them.
One thing though; you said "from" the US. Does that mean your brother is in India and is sending for the camera from the US ? If so, why not buy the card in Mumbai ? JJ Mehta sells a normal 2GB SD card for 499/- and an Extreme III for 1299/-; and they're probably cheaper in smaller shops.
Also, the Canon SX100IS is a nice camera and though I have not used this model myself, I've read good reviews about it. However, the flash is rather weak (short range) and the flash cycling time is very long, taking more than 10 seconds between shots. I suggest your brother should keep this in mind when making his choice of camera.
pimpom is offline
Old 10-07-2008, 02:30 PM   #6 (permalink)
raksrules's Avatar
Ya my brother is buying in US but he will need it to use it there itself for a few months and hence cannot buy a SD card from here. I am aware about the flash cycle times but i feel that wont be an issue in my case. I will suggest him to buy a normal one only.
Old 11-07-2008, 02:38 PM   #7 (permalink)
Google Bot
Pathik's Avatar
I agree. You wont need such speeds for Digicam use. Get the normal one.
Pathik is offline
Sandisk Cruser Micro 2GB...? prem4u Software Q&A 1 07-03-2008 03:23 PM
TV Tuner Card and LCD Monitor just like a normal LCD TV lahratla TVs / Monitors 1 27-08-2007 07:26 PM
What is cost of Sandisk Esansa 250 ssdivisiongermany1933 Mobiles and Tablets 3 17-08-2007 08:55 AM
