Old 08-07-2008, 09:31 PM   #1 (permalink)
lethalweaponforever's Avatar
Default PS 2 Emulators
Can any of u suggest a good PS 2 emulator that will play most ps2 and ps games on my pc.Is it possible for them to be joystick compatible. Can i buy any ps2 game and play it on my system using an emulator or do i have to have certain requirements for that.
lethalweaponforever is offline
Old 09-07-2008, 01:20 AM   #2 (permalink)
free world from money
Projjwal's Avatar
Default Re: PS 2 Emulators
I tried it before & it's worked....
First u need,
PCSX2 ------- ...download it from
http://www.pcsx2.net/downloads.php
Or, get it from
Digit july2008 DVD
This one is a very good video tutorial,
http://youtube.com/watch?v=eqXp65lW-SE
Recommended
CPU: core2duo 2.66Ghz Wolfdale or higher
RAM: 1GB
GPU : nvidia 8600 GT or higher
GOOD LUCK ...
Projjwal is offline
Old 09-07-2008, 09:32 AM   #3 (permalink)
i dont have the config u mentioned but will this work:
Dual core 1.8 Ghz
1 gb RAM
128mb intel 82945 express family chipset
or
Core 2 Duo 2.0 Ghz
1 gb RAM
Old 09-07-2008, 05:41 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
You need core 2 duo, 1 gb ram okay, and a dedicated graphics card is a must, i have a 7300gt which works.
dheeraj_kumar is offline
PS2 EMULATORS genre_rock Gamerz 5 28-02-2006 03:19 PM
emulators KoRn QnA (read only) 9 22-02-2005 11:44 PM
Emulators speedyguy QnA (read only) 7 26-10-2004 12:52 AM
cd\dvd drive emulators sav_more QnA (read only) 6 25-10-2004 03:41 PM
