Old 08-07-2008, 06:58 PM   #1 (permalink)
Democracy is a myth
rhitwick's Avatar
Red face Howto resize partition?
Hi,
I've windows installed in my (C) drive and a separate drive (D) for Program files.
C is of 7 GB and D is of 15 GB.
I want to resize my C drive to 12 GB. How do I do it?
O.S. currently in use WinXP with SP3.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 08-07-2008, 07:15 PM   #2 (permalink)
din
Tribal Boy
din's Avatar
Default Re: Howto resize partition?
Try Partition Magic may be ?
din is offline
Old 08-07-2008, 07:45 PM   #3 (permalink)
Let's clear up a couple of points first.
1. By "Program files", do you mean the folder "Program Files" that Windows creates automatically in C: and you have somehow moved it to D: ? OR do you mean other data that you store in D: and are not installed programs ?
2. How much of the 15GB in D: is currently used ? And how much of the 7GB in C: ?
pimpom is offline
Old 08-07-2008, 08:26 PM   #4 (permalink)
TheSaint
NucleusKore's Avatar
Use Gparted
http://gparted.sourceforge.net
It's free and open source
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 08-07-2008, 11:02 PM   #5 (permalink)
Democracy is a myth
rhitwick's Avatar
1>By "Program Files" I mean program files folder which windows creates in C drive, I've redirected it to D drive. Used a registry tweak.
2> C Drive: Free 5.27GB and D drive:12.4 GB.
Originally Posted by NucleusKore View Post
Use Gparted
I've a very much stable OS right now (means at least for last 1 month didn't need to format)
So, my question is that, can it be used without hampering existing file system??
Old 09-07-2008, 07:23 AM   #6 (permalink)
TheSaint
Back up your system partition using a hard disk imaging tool, and burn it to a dvd or cd
Then resize
Resize Partition without affecting it?? redhat Open Source 12 04-09-2008 06:03 PM
Resize partition. sid_cool QnA (read only) 9 12-03-2007 01:29 PM
How 2 resize AVATAR ? nikhilrao QnA (read only) 7 06-10-2006 02:49 AM
Resize my drive rohan Hardware Q&A 2 06-06-2006 08:27 PM
