Old 05-05-2005, 01:32 PM   #1 (permalink)
Default Sub-titles
I have sub titles for a movie in *.sub & *.txt format. I have the movie in *.avi format. I want to create a video file for burning with sub titles. Please help!
ravi.raman is offline
Old 05-05-2005, 02:43 PM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm... Did you tried using VirtualDub ...? I think there is plugin for the same use in it ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 05-05-2005, 05:19 PM   #3 (permalink)
enoonmai's Avatar
Batty is right. Get the Subtitler plug-in by Avery Lee for VirtualDub and under Video>Filters>Add, select Subtitler. Be warned that you need a SSA subtitle file, but you can convert .srt or .sub to SSA using the programs SRT 2 SSA and SUB 2 SSA. You can look at the guides here for more information on burning DVD-Video with subtitles. Or you can use Nero Recode for the same, but its not as efficient as VDub.
enoonmai is offline
Old 24-08-2005, 12:34 PM   #4 (permalink)
Self-Obsession
hittheswitch's Avatar
Default DVD lab pro
Well i've burned DVD's with subtitle using MPEG files and it works.
Try doing this:-
Convert the avi file into mpeg.Once you have the mpeg and sub file for the movie you can use DVD lab pro for writing the DVD.
I hope this works for you.
You can download DVD Lab pro from this link :-
http://www.download.com/DVD-Lab-Pro/...=dl&tag=button
I'm walking between mads,but whats the use i'm still the worst one.
hittheswitch is offline
Old 24-08-2005, 09:57 PM   #5 (permalink)
Biplav's Avatar
well u can use the plug in called vobsub too.
its pretty easy and is easily configurable in virtual dub.
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
