Old 06-07-2008, 07:05 PM   #1 (permalink)
Default Deleting Registry key
My ISP has locked me out 3 times because I was somehow creating Spam. I am now in imminent danger of having my account closed - unless I find a solution.I ran all sorts of scans but only found the culprit with Trojan Hunter.
It tells me that the Registry key is :-
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Enum/
Root/LEGACY_SYSLIBRARY
but I cannot delete it. Apparently it matches Spambot 211.
Unless I can delete this Registry entry, the only other possible recourse would be to reinstall Windows XP and hope that the new Registry is clean.
Does anyone have a better solution?
chopendoz is offline
Old 06-07-2008, 08:18 PM   #2 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Default Re: Deleting Registry key
Deleting random registry keys is never a good idea.
Try nod32(antivirus) and scan in safe mode.
Also u can use something like winpatrol to control what runs on your system and monitor any changes. Heck its possible that just running winpatrol could solve all problems..
After you manage to solve your problem PLZzzzzz stop using internet explorer. Use firefox or Opera
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 07-07-2008, 12:38 PM   #3 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
format ur c: , if possible ......
OR try using TuneUp Utilities 2008 ! ! !
http://www.thinkdigit.com/forum/reviews/91254-tuneup-utilities-2008-a.html#post866742
... W H O T ...
ax3 is offline
Old 07-07-2008, 01:54 PM   #4 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
@ax3
use the registry cleaner, coz it works best for me
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 07-07-2008, 08:49 PM   #5 (permalink)
TheSaint
NucleusKore's Avatar
Or use your internet only with Linux, that's the safest at present
No I am not trolling here, but it is a VERY GOOD AND PRACTICAL SOLUTION.
You can access all your windows data from Linux partitions, and when you really want to use Windows switch off your router/modem and then boot into Windows.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Deleting folder with no name stonecold8 QnA (read only) 8 18-11-2007 10:08 AM
Deleting background kumarn_2004 Software Q&A 10 15-03-2007 10:34 PM
Deleting Pagefile.sys blackpearl75 Software Q&A 16 27-01-2007 12:39 AM
deleting emails gofeddy Internet & WWW 3 15-01-2007 01:58 PM
Deleting Error william QnA (read only) 1 27-02-2006 09:32 PM
