Old 05-07-2008, 09:05 PM   #1 (permalink)
Default Deleting files permanently, search and delete
A utility which allows search and delete permanently for a specific extension from computer.
I found utility like Inferno (search keyword inferno sourceforge in google), But that allows files to be dragged onto it to be deleted.
I want certain extension files to be searched and deleted.
Does anyone know anyway of doing it...?
dabster is offline
Old 05-07-2008, 11:35 PM   #2 (permalink)
I WANT MORE FPS!!
adithyagenius's Avatar
Default Re: Deleting files permanently, search and delete
Search for *.<extensionname> in all your local drives. After the search is complete press Ctrl+A followed by Shift+Del.
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
adithyagenius is offline
Old 05-07-2008, 11:41 PM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
How about :
rm -f `find . -name *.log`
[Edit] Unix specific only ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 05-07-2008, 11:50 PM   #4 (permalink)
I WANT MORE FPS!!
that requires linux installed with ntfs-3g tools.
Old 06-07-2008, 12:02 AM   #5 (permalink)
Well .. Now I am wondering why I wrote that reply .. I am sure I read something about Unix there and thats why I wrote it .. .. Maybe I need a nice cup of coffee ..
Old 06-07-2008, 08:04 AM   #6 (permalink)
del /f /s /q *.<extension>
If you run the above command from each root partition, you will effectively delete all files of the type (unless they are hidden/system files)...
For hidden/system files to be deleted, you need to first run on each root partition
attrib -s -h *.<extension> /s
Arun
sakumar79 is offline
Old 07-07-2008, 12:42 PM   #7 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
use TuneUp Utilities 2008 ! ! ! ....... shredder does the job ......
http://www.thinkdigit.com/forum/reviews/91254-tuneup-utilities-2008-a.html#post866742
... W H O T ...
ax3 is offline
deleting files imported_tarang QnA (read only) 2 09-04-2006 01:11 AM
Deleting Google search bar options ashu888ashu888 Internet & WWW 3 06-01-2006 09:50 PM
deleting files permanantly? Saharika QnA (read only) 7 24-11-2005 02:23 AM
Bypass the Recycle Bin when deleting files. rajesh Tutorials 10 14-05-2005 12:25 PM
Deleting files under Win98 SE sms_solver Software Q&A 10 07-09-2004 12:41 AM
