Old 03-07-2008, 08:00 AM   #1 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Arrow TV tuner card Querries .
Hi i am planning to buy a tv tuner card , but the problem is i dont know how to connect the TV signal cable to it . i have one cable connection and the tv is near the pc , 3 m .
can i have tv running on my pc without extra cost?
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 03-07-2008, 11:03 AM   #2 (permalink)
The real Bond
yogeshm.007's Avatar
Default Re: TV tuner card Querries .
Just as you connect to your TV. Look out for the adapter kind of thing in the market (dont know exact name) with one input and two outputs (one each for TV and PC). Alternatively you can also do a jugar (hope you get it) at home.
Depends upon your cable operator. Most wont allow without additional charges, but you can easily disguise the second connection from him/her.
yogeshm.007 is offline
ExpressCard - Data Card and TV Tuner Card hailgautam Software Q&A 1 20-10-2006 12:30 AM
Tv tuner card / Graphics card for my config ... gsenthil PC Components / Configurations 4 08-09-2006 07:23 PM
Query Reg Graphics card/TV Tuner card tiwariG QnA (read only) 10 10-09-2004 06:38 PM
