Old 04-05-2005, 04:29 PM   #1 (permalink)
Default Mac Interface
hi
Want to make my Computer UI look like just that of a mac. Can anyone specifically tell me which softwares or skins ( like style xp, Windows fx) should i download.
mako_123 is offline
Old 04-05-2005, 05:32 PM   #2 (permalink)
Do u have Windows Tips N Tricks cd.
There were soo many skins for that.
Lovedeep Wadhwa
cheetah is offline
Old 04-05-2005, 05:41 PM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Which cd is this?
navjotjsingh is offline
Old 04-05-2005, 07:03 PM   #4 (permalink)
Hehe sorry for confusing ya......
Thats not from Microsoft.It came once with Digit.CD named Windows Tips N Tricks or may be Tips N Tricks.
Lovedeep Wadhwa
cheetah is offline
Old 04-05-2005, 08:38 PM   #5 (permalink)
Hey you can get the Mac transformation pack from
http://files.tcmagazine.net/windowsx...acosx1beta.zip
or from tcmagazine.net
upendra_gp is offline
Old 04-05-2005, 10:09 PM   #6 (permalink)
try this http://www.mobydock.com/
drvarunmehta is offline
Old 04-05-2005, 10:25 PM   #7 (permalink)
Walking, since 2004.
mail2and's Avatar
get FlyaKiteOSX from http://osx.portraitofakite.com/
Get Tiger wallpapers from: http://patrickyan.net/ul/TigerDesks.zip
Get Tiger Iconpackager icons from:
http://dreamteam69.free.fr/Xero/OSX_Panther_Icons.ip
Get Tiger PNG icons from:
http://dreamteam69.free.fr/Xero/OSX_..._Icons_PNG.zip
Thats about it
Mumbai, I miss you. :(
mail2and is offline
Old 04-05-2005, 10:32 PM   #8 (permalink)
enoonmai's Avatar
More software that you might like to get that Mac look.
StyleXP
ObjectBar
ObjectDock
YzShadow
Rainlendar
Samurize
Mac OS X Icons (12MB)
You can get more themes and skins from www.themexp.org
Playing FEAR XP/LSW2
enoonmai is offline
Old 05-05-2005, 01:50 AM   #9 (permalink)
What is the use of Samurize.
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 05-05-2005, 10:19 AM   #10 (permalink)
enoonmai's Avatar
Samurize is a system monitoring and desktop enhancement tool. It can be tweaked to resemble the Konfabulator for the Mac, and pretty much do anything from display CPU usage to fetching stock quotes and weather information.
enoonmai is offline
Old 05-05-2005, 05:21 PM   #11 (permalink)
Hi upendra
i downloaded and applied the mac transformation pack from tcmmagzine.net but it didnt made any change to boot screen or background. Is there any other software i need to install before it.
mako_123 is offline
Old 07-05-2005, 02:33 PM   #12 (permalink)
no you don't need to install any other tool before it.you can edit the boot.ini file by adding the following commands
/kernel=x.exe
Where x is the name of the bootscreen you downloaded or you can use Style XP to customise
You can use these tools or sites
interfacelift.com/
forevergeek.com/geek_articles/ windows_xp_to_mac_os_x_gui_conversion.php
www.osx-e.com/
http://www.versiontracker.com/dyn/moreinfo/mac/12745
8)
