04-05-2005, 02:23 PM
Hard disk NTFS-RAW
I have 2 HD's 40 GB's each.Yesterday when i started the computer i copied some data from D: - E:[I have 4 partsC,D,E,F]But after that i was unable to view E:\ contents. In My Computer when i tried to Double Click on it says that E:\ is not accesible.Acces is denied .When i checked its properties it shows RAW file System.Which is NTFS!Pleasse help me immediate Solution required.
04-05-2005, 03:24 PM
it seems a partition corruption!!
i recommend the use of some data recovery software!!
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
04-05-2005, 03:31 PM
Did it not give an error at the time of copying.
**** happens
04-05-2005, 06:18 PM
I am Optimus Prime
A raw partition is a partition on your hard disk that is not formatted and that does not have a drive letter assigned to it.
Try this
1.Click Start, and then click Run.
2.In the Open box, type cmd, and then click OK.
3.At the command prompt, type MountVol /E, and then press ENTER.
After you follow these steps, the following registry key is changed from the default setting of 1 to a setting of 0:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\MountMgr\NoAutoMount
04-05-2005, 08:18 PM
Hey Navjot your trick didn't work.There is no key regarding to this
04-05-2005, 08:20 PM
If the partition is gone then the best way to recover it is using linux (any live cd will do) run fdisk and in the raw area make a ntfs / fat partition as the case may be write the changes to the disk and reboot in windows.
This happened to me a few times I lost antfs partition but got it back with full data using the above tecnique.
**** happens
04-05-2005, 08:27 PM
I am Optimus Prime
Just reformat the partition using any file system(do it using fdisk as pradeep_chauhan said) beacuse RAW refers to a new unused partition.
04-05-2005, 08:31 PM
Please do not reformat you will loose all data.
**** happens
04-05-2005, 08:47 PM
I am Optimus Prime
Sorry.....don't reformat.
04-05-2005, 09:14 PM
then if u know a free one tell me then as my drives are NTFS
05-05-2005, 06:03 PM
I am Optimus Prime
Have you tried pradeep_chauhan's tip as he said he got his data recovered in full.
06-05-2005, 09:17 AM
I don't know how to operate linux plz tell me a simple idea from which i can recover my data safely
06-05-2005, 10:23 AM
hey hey hey..
dont do any reformat etc, since the error is "access denied".
log in as administrator
go to drive properties, check in security tab if your user name is given read, write permissions, if not give it permissions,
if this dosent work take a good antivirus and give a full system scan. and do a through "chkdsk" for that drive.
if nothing works use PC inspector and recover lost files and then reformat the drive.
This generally happens if your administrator denies u the permission to access the drive,
You dont Understand Something..
DESTROY IT
.... Secret of survival
06-05-2005, 10:35 AM
dont belive me mail me on ifakeit@gmail.com and i will send you screen shots to prove it.
DESTROY IT
06-05-2005, 04:07 PM
06-05-2005, 08:29 PM
You need to login as system administrator to view security settings, any other account it is not possible.
DESTROY IT
07-05-2005, 02:55 PM
i only have one account on my PC which is administrator account.Please tell me how to recover using linux[the procedure step by step]
Search this Thread |
