Old 01-07-2008, 10:17 PM   #1 (permalink)
Wise Old Mouse
mrintech's Avatar
Question How to edit this particular blogger layout?
Friends,
I recently downloaded a blogger theme from a site (in .xml format). But as shown in image below I cant't edit the circled areas.
How I can do so?
btw here's the HTML code for this template:
http://rapidshare.com/files/12634970...-skin.txt.html
pls help
mrintech is offline
Old 01-07-2008, 10:46 PM   #2 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: How to edit this particular blogger layout?
For the header menu links, you must click them(Edit me) directly.
For the Subscribe sidebar you have, you can see code like this in the template file:
<h2>Subscribe</h2>
<p>
     <a class='feed-link' href='/feeds/posts/default' target='_blank' type='application/atom+xml'><img src='http://i161.photobucket.com/albums/t219/freetemplates4/feed-icon-32x32.jpg'/> RSS Feed (xml)</a>
</p>
<h2>Powered By</h2>
<div class='credits'>
<p>
Skin Design:
<br/>
<a href='http://freeskins.blogspot.com/' title='Free Template Downloads For Blogger'>Free Blogger Skins</a>
</p></div><!-- end credits -->
<p id='powered-by'><a href='http://www.blogger.com'><img alt='Powered by Blogger' src='http://buttons.blogger.com/bloggerbutton1.gif'/></a></p>
You can edit or delete it.
http://twitter.com/blueshift155
blueshift is offline
Old 01-07-2008, 11:58 PM   #3 (permalink)
Wise Old Mouse
mrintech's Avatar
Question Re: How to edit this particular blogger layout?
Nothing is happening when i click "edit me"
mrintech is offline
Old 02-07-2008, 01:21 AM   #4 (permalink)
Wise Old Crow
blueshift's Avatar
Ok...its here. Just above the code I given in my first post.
<div id='header-wrapper'>
<b:section class='header' id='header' maxwidgets='1' showaddelement='no'>
<b:widget id='Header1' locked='true' title='Tropical Retreat XML Theme (Header)' type='Header'/>
</b:section>
<div class='top-nav'>
<ul class='nav'>
<!-- Add or modify your links below using the examples, replace the # with your actual link and change "Edit Me" to your link name. The home page link works just like it is. You can add more lines or remove the ones you don't want before the closing </ul> -->
<li><a href='/'>Home</a></li>
<li><a href='#'>Edit Me</a></li>
</ul>
</div>
</div><!-- end header-wrapper -->
Edit the thing in bold.
Old 02-07-2008, 09:41 AM   #5 (permalink)
Wise Old Mouse
mrintech's Avatar
Cool Re: How to edit this particular blogger layout?
@Blueshift
Thanx man.
Dude i wanna ask one thing from you that if i wanna replace "edit me" field[s] with fields like "photogallery", "contact me" etc. etc. What must be the link i must give?
mrintech is offline
Old 02-07-2008, 12:08 PM   #6 (permalink)
Wise Old Crow
blueshift's Avatar
<li><a href=www.yourdomain.com/about.html>About</a></li>
<li><a href=www.flickr.com/uraccountname/>Photogallery</a></li>
<li><a href=www.yourdomain.com/contact.html>Contact Me</a></li>
just giving that as example. The links may vary in your case.
I never used blogspot..but after you create a page their(not post), you will get a link to that. Just replace it accordingly.
Old 02-07-2008, 02:12 PM   #7 (permalink)
Wise Old Mouse
mrintech's Avatar
Wink Re: How to edit this particular blogger layout?
Hey dude, I know this what you mentioned above. Actually I want whenever a user click on any of the TABS he/she remains in my blog only. I don't wanna redirect them to other domains.
Well leave it. This theme s**k big time
Do you know any good site where i can download good, efficient Blogger Theme?
mrintech is offline
Old 03-07-2008, 12:08 AM   #8 (permalink)
Wise Old Crow
blueshift's Avatar
well use <a href='#'> then.
Google for blogger themes.
Old 03-07-2008, 12:37 AM   #9 (permalink)
Wise Old Mouse
mrintech's Avatar
Thanx Dude
mrintech is offline
While installing Photoshop 7, it asks for 'LAYOUT.BIN', help me pls mobileman Software Q&A 2 01-11-2007 07:09 PM
web pg layout ! ! ! ax3 QnA (read only) 7 30-08-2006 09:56 PM
Webpage's Layout eagle_y2j QnA (read only) 4 15-08-2006 12:12 PM
layout drawing s/w form computers.....??? taken Software Q&A 3 22-02-2006 10:34 AM
plz help 4 website layout [urgently] gycapri QnA (read only) 5 22-11-2005 07:36 PM
