Old 01-07-2008, 10:02 PM   #1 (permalink)
User Name's Avatar
Question Can't able upload files.
I can't able to upload files using OPEN DNS?
Is there any good DNS available?
User Name is offline
Old 01-07-2008, 10:06 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: Can't able upload files.
I doubt if Open DNS has to do something with uploading files. once it identifies the server, its task is done.
गीक होना माँगता
victor_rambo is offline
Old 01-07-2008, 10:12 PM   #3 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
yup what is open dns going to do with uploading files
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 01-07-2008, 10:35 PM   #4 (permalink)
User Name's Avatar
then what's the prob.?
Whenever i upload any file/image on any website the page gets stuck and then goes blank
to post this quick replay i hav restart my pc and router.
Old 01-07-2008, 11:39 PM   #5 (permalink)
हॉर्न ओके प्लीज़
Hmmm...I think I am getting some hints.
BTW which browser are you suing? Is that Internet explorer? If yes, my first advice will be switch over to firefox or opera because they can handle javascript without causing severe frustrations to the user.
But if you are already using firefox, then probably there is some javascript issue. What may be happening is that CPU usage shoots to 100% and your PC freezes.
Next time, just open the task manager(Ctrl+Shift+Esc) and check the CPU usage while this happens. Also are you using the firebug extension with firefox? It is known to shoot ur CPU usage to 100% on complex/long javascripts.
गीक होना माँगता
Old 02-07-2008, 02:19 PM   #6 (permalink)
User Name's Avatar
First I use firefox 2 and now firefox 3 beta 5.The prob. is same in IE or firefox.
Actually when i upload a image on rapidshare it uploaded completely but then page got stuck when generate code for it.
Even posting here is not easy for me.Some times it post reply sometimes hangs.
for D/L there is no prob.
I checked CPU Usage it is 20-30%.
When i click on post quick reply sever didn't respond,while other sites can be opened easily.
How to upload or edit files in a .org site i got free? koolbluez QnA (read only) 1 15-10-2005 04:55 PM
How to upload... ?? ShekharPalash QnA (read only) 6 31-07-2005 07:38 PM
I want to upload files pirates1323 QnA (read only) 13 01-06-2005 07:46 PM
how can i upload files on ftp through IE..?? pr@k@sh QnA (read only) 8 28-10-2004 02:42 PM
