Old 30-06-2008, 03:34 AM   #1 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Buying Pen Drives in Bangalore
I am looking for some good pendrives in bangalore. Which is the best place here to buy them ? Most places here ask heavy prices, like Rs. 350 for just 1GB. Many shops stock damn slow drives like Transcend Jetflash V30.
One of my friends bought a 1Gb JF V30 in JC Road for Rs. 125/-. Is it worth it ? Is JetFlash V10 priced similarly ? What about Moser Baer 1GB pen drive ?
I basically need a simple cheap drive for rough use, especially on machines that are NOT mine and might possibly have windows viruses which I end up laughing at. It would need to hold often small data, with hundreds of files typically below 500KB and some MP3s.
I also want a drive thats compatible with YAFFS2 File System.
Finally, what are the price ranges I can expect fast 8GB drives to come at ?
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 30-06-2008, 08:40 AM   #2 (permalink)
gopz's Avatar
Default Re: Buying Pen Drives in Bangalore
You probably need to make a visit to SP Road and do some research and then buy it there. And post your observations here
gopz is offline
Old 30-06-2008, 01:15 PM   #3 (permalink)
The Smaller Bang
When I went to SP Road the last time, I remember seeing 8GB JetFlash V30 drives for 1050 rupees.
But I don't remember the prices for "performance" pen drives.
And the very objective of this thread is to find out if I can get anything cheaper than 1GB V30 for 125/-, using other people's experience.
Old 30-06-2008, 01:50 PM   #4 (permalink)
I would suggest you to go to the following shops for buying any computer component:
Pawan Computers - 22998465 / 22998471
Surabhi Computers - 22998357 / 22998457
Anandit Infotech (main dealer for Transcend Products) - 22998399 / 22122510
They give it at a reasonably low price.
Don't buy the 1GB drives from J.C. Road man. J.C. Road is 'Automobile/Motorcycle products Haven' doing retail business.
Please don't buy the Moserbaer 1GB pen drive. Its very slow & its durability is very less. My uncle got one & it was not operational in abt 2-3 months though he uses it occasionally. I think warranty is only 1-3 months for those.
I basically need a simple cheap drive for rough use.
Here are my recommendations for:
Cheap, Medium Speed
* Sandisk Cruzer - 8/16 GB - ~ Rs
* Corsair Flash Voyager - 8/16 GB - Rs. 1500 / Rs. 3400
* Transcend V Series - 8/16/32 GB - Rs. 1150 / Rs. 2450 / Rs. 4900
* Kingston Data Traveller 100/110
They are around that range. Prices are approximate. The Transcend prices are from Anandit Infotech. Asked them the prices today.
Slightly Expensive, High Speed
* Corsair Flash Voyager GT - 8/16 GB - ~Rs. 5000 / ?
* SanDisk Extreme Cruzer Contour - 8/16 GB
* Transcend JetFlash 160/168/2A Series USB - 8/16 GB
* Kingston Data Traveller 400
Prices will be above Rs. 4000+ range for 8GB ones.
Hope the above helps.
shadow2get is offline
Old 30-06-2008, 03:35 PM   #5 (permalink)
The Smaller Bang
Cheap, Medium Speed
I am intrested in mainly 1GB pendrives, that too ones which can last an year or two under normal use, and I don't think write speed needs to be the most important criteria here, since most of the time, I would be only reading from the pendrive.
I had set aside Rs. 130 for one, but now I spent all of it and I am saving from the scratch again and I ended up with 65 so far, and so once again I can go for the old budget.
The 8GB pendrive I am looking for should not be expensive enough to match Hard Drive costs, because in that case, a pendrive would be utterly pointless for me. So most of the pendrives you mentioned are out of the propables list.
I think you quoted the MRPs for the pendrives. But I am intrested in stuff which comes below a grand.
Also, from most reviews, I have concluded that transcend manufactures both the fastest (JF V10) and the slowest (JF V30) pendrives. I heard V10 is quite affordable indeed at 8GB. But since both have good loooooong life spans, (tested and proved using a V30 512mb drive and lots of V10 reviews), I am going to go for JF V30 for the 1GB pendrive.
Any advice here ? 1GB pendrive at around Rs. 130/- ? Is there something I can get which is better than JF V30 ?
Finally, when you mentioned the price for 8GB transcend V series, were you refering to the V30 or the V10 ?
Old 02-07-2008, 04:37 PM   #6 (permalink)
The Smaller Bang
bump
Old 03-07-2008, 01:16 PM   #7 (permalink)
About the 1GB drive, you can get a Transcend 1GB V30 Series for Rs. 230 with 1 year warranty. If you feel that it is too expensive, you could go for the 130 bucks one. Dunno about the warranty in this case.
The 8GB Transcend drive is a V60 Series one. All Transcend models have 1 year warranty. Since you are not willing to spend more than 1k for the higher capacity drives, then you could go for this one. But I suggest you go to SP Road & ask for the prices there. They will probably give it for within 1k.
Also, if you aren't concerned about Speed & lesser warranty, you could go in for other cheap brands which are aplenty in SP Road.
Old 03-07-2008, 04:47 PM   #8 (permalink)
The Smaller Bang
^^thanks. this means I am getting ONLY the Rs. 125 1GB jetflash V30.
Old 03-07-2008, 04:52 PM   #9 (permalink)
M3TAL H3AD M3
skippednote's Avatar
wats the price of 1 gig and 2 gig pendrive any brand
I spit Rainbows.
skippednote is offline
Old 16-08-2008, 09:16 PM   #10 (permalink)
The Smaller Bang
BUMP and update:
I just got a Transcend Jetflash V30 2GB Pendrive from Sahara in SP Road for Rs. 310. It comes with bill and warranty (life time). Is it worth it ?
And how do I use YAFFS2 file system in it ? I want it for maximum performance.
Old 17-08-2008, 05:12 PM   #11 (permalink)
Hmm MHG ... am surprised you didn't go for the 1GB drive @ 120 bucks.
Anyway, I felt that you should have gone for the 8GB drives at least now.
2GB @ 310 bucks is slightly expensive than 8GB @ 1000. But ur main criteria was not to go beyond 400/500 bucks. It is worth the money & the warranty you got.
Regarding the usage of YAFFS, you could have a look at the following link:
HOWTO incorporate YAFFS
Simple HOWTO for getting started with YAFFS and using it as a root filesystem
Old 17-08-2008, 10:17 PM   #12 (permalink)
Dreamweaver
Gigacore's Avatar
@ nuthead..
Howz the transfer speed man ? Just tell me time taken for moving 100 MB of mp3 songs so I can estimate the speeds...
If its good, am gonna buy one too.. S.P Road is just an 20 minutes walk from my college
Gigacore is offline
Buying Optical drives realdan Hardware Q&A 30 01-09-2008 02:11 AM
Buying Legitimate Software in Bangalore sourav123 Chit-Chat 2 29-01-2008 10:12 AM
HDD drives detected as removable drives chicha QnA (read only) 6 22-01-2008 01:55 PM
HELP!!! Buying a Pc in Bangalore HELP!!!Need config n price bunny01in QnA (read only) 4 23-09-2005 03:56 PM
