Old 03-05-2005, 08:21 AM   #1 (permalink)
sujeet2555's Avatar
Default blue screen of death
my system is window xp with sp2 on p4.it was running nice ,but one one automatic update shows me with some security updates. i downloaded them and then installed .when i restarted it shows blue screen and then restarted.i am unable to see the error messege ,as it comes preety fast.i can't boot in safe mode neither nor when i choose "last known good configuration".please help me i !
s.k.
sujeet2555 is offline
Old 03-05-2005, 10:48 AM   #2 (permalink)
chinmay's Avatar
try repairing ur os with the xp cd....if doesnt work u'll have to reinstall ur os by formatting the root drive...but u can back up important files thru dos if u know the path of those files...
I Blog at - http://www.chinmayspeaks.com
chinmay is offline
Old 03-05-2005, 04:44 PM   #3 (permalink)
ohh.....bad news..... Try to bet your money on knoppix.
Get the knoppix cd..from linux group and ask them to help
you over phone.(most times they help you very well)
You can work in GUI nearly like windows...instead of using
shitty ms dos
Then u will fall in love with knoppix and slowly eradicate winxp
h4xbox is offline
Old 03-05-2005, 05:08 PM   #4 (permalink)
swatkat's Avatar
Perform a Windows Repair. Follow the steps given here.
http://swatrant.blogspot.com/
swatkat is offline
Old 04-05-2005, 03:32 PM   #5 (permalink)
dont start repairing/reinstalling/blah-blah-ing your windows installation unnecessarily. check out the following links from microsoft knowledge base:
http://support.microsoft.com/default...b;en-us;314466
http://support.microsoft.com/default...b;en-us;310396
nutca5e is offline
Old 04-05-2005, 04:14 PM   #6 (permalink)
Default hi
It is better to perform a full installation of windows.
mako_123 is offline
Old 05-05-2005, 10:33 AM   #7 (permalink)
sujeet2555's Avatar
Default Re: blue screen of death
s.k.
Old 05-05-2005, 10:47 AM   #8 (permalink)
Boot with your bootable Windows XP CD and repair the OS installation
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 05-05-2005, 11:41 AM   #9 (permalink)
Dude may be you can help us by specifing what was the exact update u installed?, what is the partition u use-ntfs or fat?
also try the following after u get the options menu go to command promt and try out the
chkdsk command. and fix any bad sectors.
aslo it may be due to bad installation of the update or ur internet connection failing in course of online update.
for this u will need to perform a repair install.
boot trou ur XP bootable CD, and go to repair install, incase ur not familiar it asks for repair 2 times, go for the 2nd time install.
You dont Understand Something..
DESTROY IT
.... Secret of survival
kiran_k is offline
