Old 29-08-2004, 12:05 PM   #1 (permalink)
Rebooting
Choto Cheeta's Avatar
Default restart problem with my wiondows 98 SE
I cant restart my win98SE.... Every time i rty to do it, a Fatal error is displayed in blue screen & computer hangs there......... but i can shut down it properly...... it happenes only at restart........
Pls help...........
Choto Cheeta is offline
Old 29-08-2004, 12:26 PM   #2 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Give a detailed desc. of th error, please.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 29-08-2004, 04:55 PM   #3 (permalink)
the same prob comes in xp also
it is for the same cause. he is saying the one that happens in win98se which is the same as in irql_not_less_than_equal
rj2k is offline
Old 31-08-2004, 01:35 PM   #4 (permalink)
Rebooting
Default what kind of details do u need........
In my case it does shows a long error massage..... saying "he corrent program is not responding needs to be termineted. press ctrl+alt+del to restart" with a error code...... in white font & blue screen......
Old 31-08-2004, 03:32 PM   #5 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
And what program is that ...??
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 02-09-2004, 10:00 AM   #6 (permalink)
Rebooting
pls yaar read the full page........ in the top i ask the question........
Old 02-09-2004, 09:44 PM   #7 (permalink)
The problem is that You have installed some software(or hardware) which doesnt have full compatible with the OS like (e.g installing Softice in XP) uninstalling ur software one by one and find the one which causes it......
Knowledge is power!
curvenger is offline
