Originally Posted by Betruger
then...
if a drive have formatted in NTFS, why windows made to create a compressed file using built-in-compression utility which is already resides in a compressed File Systeme.?
NTFS compression compresses a single file but using Compressed zip file feature, you can create a single ZIP file containing more than one file/folder which you can share with others.
Another difference is, NTFS compression compresses the file automatically unless you disable it, on the other hand Compressed Zip file allows you to compress no of files whenever you want without using any 3rd party utility.
