FYI, Distiller is INCLUDED along with the PageMaker 7.0 install. As long as you don't use it to create PDF 1.5 documents, it should work. While Adobe recommends that you install Acrobat/Distiller 6.0 and then choose custom jobs to export 1.5/1.4/earlier PDFs, I know of a lot of PageMaker professionals that use the bundled PageMaker+Distiller to churn out PDFs instead of switching to Acrobat+Distiller. You don't need Acrobat+Distiller for exporting from PM7.0, you can do very well with PageMaker+Distiller. As for the error message that you have been so gracious to put a screenshot of, everyone knows that you cannot create a PDF without a PDF creator or at least a PostScript printer that you can distill/GhostScript/GSView later. That was never the point, the only thing is that saurav is experiencing a known bug in the PM7.0 version and is having trouble upgrading. Once he gets that fixed, I am sure he will be able to churn out PDF files without any problems.
Playing FEAR XP/LSW2
