Old 25-06-2008, 07:31 PM   #1 (permalink)
Default burning iso on flashdrive???
hello guys i want to know that if it possible to burn any iso image on flash drive instead of cd or dvd through any software and then can be used to run live live distrosss.......temme is it possible..???
maxy69 is offline
Old 25-06-2008, 08:56 PM   #2 (permalink)
Here Since 2003
Indyan's Avatar
Default Re: burning iso on flashdrive???
Check out Pendrivelinux. That may help you.
My Blog :: http://www.pallab.net
Twitter :: http://www.twitter.com/indyan
Indyan is offline
Old 25-06-2008, 09:00 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Afaik, its not possible
For the simple reason that, BURNING really means 'burning/"writing on" the Disk', this is NOT possible for a flash drive jus bcoz there is NO burner available,
however, u can carry the ISO image file with u along with a virtual drive s/ware like Nero image drive (comes with NERO), Daemon tools, alcohol etc..etc... and then use it on a system u intend to, but then also, its no USE (if the system doesn't allow booting from a UBA and tat too from an IMAGE ISO file..)
Best way, burn it (literally, the recorder writes data onto the disk by creating pitts (only) and crests )..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 25-06-2008, 09:18 PM   #4 (permalink)
Here Since 2003
Indyan's Avatar
Anyway, just found out that he has opened a thread regarding the same issue in the OS section.
So thread closed. Please open dont open multiple threads for a single topic.
Indyan is offline
Difference between burning CD/DVD as MP3 Vs burning as DATA CD/DVD in Nero ajayritik Software Q&A 1 06-09-2007 07:33 PM
k3b not burning. cynosure Open Source 7 02-07-2007 01:59 AM
Burning DVD on CD ComputerUser QnA (read only) 11 26-05-2007 01:07 PM
- Burning DVD to another DVD !! Dipen01 QnA (read only) 8 05-10-2006 04:34 PM
CD/DVD Burning SW src2206 Software Q&A 21 28-06-2006 09:35 AM
