Old 25-06-2008, 04:48 PM   #1 (permalink)
ComputerUser's Avatar
Default 60hertz or 75 hertz?
My DELL LCD monitor supports 1440 x 900 @ 75 hertz. Should I keep it at 75 hertz? Will it reduce the life?
ComputerUser is offline
Old 25-06-2008, 06:01 PM   #2 (permalink)
The real Bond
yogeshm.007's Avatar
Default Re: 60hertz or 75 hertz?
As i read somewhere else before, refresh rate has absolutely no impact for LCD monitor if DVI is the interface used. In case standard VGA connector is used you should skip to what the manufacturer prescribes.
yogeshm.007 is offline
Old 25-06-2008, 08:54 PM   #3 (permalink)
TooR
alok4best's Avatar
Nothing will happen to screen no matter which rate u use.
But it always has an impact on ur eyes.
Lesser refresh rate means more stress on eyes.
So I wud suggest, reduce ur resolution a bit and go for 85Hz.
I wish !!
alok4best is offline
Old 25-06-2008, 11:20 PM   #4 (permalink)
The real Bond
He has LCD monitor, not CRT. They are very different in how they display images.
Old 25-06-2008, 11:35 PM   #5 (permalink)
TooR
alok4best's Avatar
^^ it doesn't matter much, even on LCD monitor if u set a low refresh rate , the display will not be smooth.
I wish !!
Monitor unable to run at 75 Hertz sonu1983 Hardware Q&A 5 04-02-2008 09:54 AM
