Re: Tv Tuner
I have been using local brand costs 1.5K the picture quality is decent at vcd resolution, you can expect more at that price, but if you want good picture quality and recording quality you must spend much more the leadrek, or pinnacle 2.5K or above will help you, and the cable signal must be good enough to use it efficiently.
"It Is Not The Position You Stand, But The Direction In Which You Look."
