Old 29-08-2004, 10:13 AM   #1 (permalink)
Default ISO-IMAGE
well in the august issue of digit, the dvd which was provided had the
ISO-image of suse-linux. The iso image size is 700mb while that of the the linux if burned onto a disc would be 1.3gb. Can anyone tell me how such ISO-images with commpresed data can be made.
sridhar8310 is offline
Old 29-08-2004, 10:22 AM   #2 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
The ISO image burned on a CD would also be 700 MB, not 1.3 GB. Remember, a CD can hold only 700 MB
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 29-08-2004, 10:54 PM   #3 (permalink)
Dont extract anything from the ISO Image...burn it as it is...If you are using Nero 6, Go to RECORDER>BURN IMAGE>select the image>BURN
Dats it...
Enjoy!
sUlPhUr|nE` is offline
Old 30-08-2004, 10:28 AM   #4 (permalink)
AskRajesh
rajeshjsl's Avatar
yes Kl@w-24 is right .
but virtual cd can create an image with compression in its own format
rajeshjsl is offline
Old 01-09-2004, 08:26 PM   #5 (permalink)
yes Kl@w-24 a cd may hold 700mb but when i tried to burn of the iso image(700mb) i told u about onto a disc it wouldn't it said that the capacity was not sufficient.
Also when i loaded the iso image using imagedrive(nero), i found out that the actual size was 1.3gb.
So what do u have to say now
Old 01-09-2004, 09:45 PM   #6 (permalink)
JAK
What the Heck !
JAK's Avatar
Explorer view
Mounted Image
It doesnt look to be 1.3 GB to me...
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 01-09-2004, 11:01 PM   #7 (permalink)
Jai Suresh
lywyre's Avatar
Just right click the ISO and burn it with DVD Decryptor. (If you don't have download it. It is just under 1MB).
lywyre is offline
Old 01-09-2004, 11:44 PM   #8 (permalink)
happened in my 3 in 1 windows 2003 cd
the thing is there are 3 os's on it ... but theres is essentially one folder
yet it gave a size of 3 times the iso file when i checked
yet it burned on the cd
i guess it checks the size of all the folders mentioned even if its a repeat ....
thats the only logical way i could figure out
No Mercy, No Limits.
theraven is offline
Old 02-09-2004, 01:09 PM   #9 (permalink)
tuxfan's Avatar
In Nero 5.5, how do I do it? If I create a data CD, it will just burn the .iso file and not the image. Nero saves its images as .nrg files and not .iso files
tuxfan is offline
Old 02-09-2004, 01:16 PM   #10 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
In Nero, choose 'Burn Image' from th File menu and select th image file.
Flickr!
Kl@w-24 is offline
Old 02-09-2004, 09:48 PM   #11 (permalink)
agree with kl@w
or if ur still skeptical
use ultraISO ... it has an inbuilt nero burner for the iso's
theraven is offline
Old 03-09-2004, 10:57 AM   #12 (permalink)
tuxfan's Avatar
:roll: silly me I have lost the drive to do even a little bit of R&D since I have been visiting tech forums. Thanks.
tuxfan is offline
