Hi
Hi
Build by ATI radeon 9800pro 128mb
1)It sometimes displays artifacts or something that should not be in games.But this afternoon for sometime it i think was not showing artifacts etc for sometime,not the whole time.
2)The text appears distorted or cut sometimes and often when another thing is dragged over it , if even it is highlighted by the mouse the distortion goes.
3)Sometimes the monitor becomes pinkish and sometimes flickers pink like i think so probably.
Once when comp was starting , the bios text was pink and something otherwise written in yellow maybe ,'energy' or something i think appeared orange like.
4)Sometimes the screen has dots of different colous and sometimes they go by opening a window if they are in the taskbar for example but if they are in the desktop screen like wallpaper they may not go.
5)UT2004 i kind of loose control over the keyboard and mouse.
5)In collin mc rally 2004 and 2003 were more or less fine in this respect however in 03 the movie qulaity was not too good.
6)Is this a :
psu problem
heating problem
graphic card problem
I have 300watts mercury
Should a 450watts smart power antec solve the prob?
How do i check the gpu temp?
For 1.7willamette
40gb 7200rpm
256mb sd ram
is 41 for cpu and about 50 for system ok after using the comp for few minutes?
finally should i have it rma'd
what will be the total cost .
i from delhi will have to send by courried or something to californi to uncle then then he will need to send to company and the same process will go backwards.
what will be total cost , time?
will there be customs?
is this temp normal with 2-3mintues ac switch on before and running
cpu-27
system-31
4-5minutes splinter cell pandora tomorrow
cpu-31
system-40
also , i think i installed collin mc rally 03 yesterday,was working,now display prob
how much do you feel total cost would be of custom + transport etc
what is the sum of this cost + the cost i can sell the card after repairs
is it worth going for the a new one for alomst the same price.g6600gt
