Old 23-06-2008, 10:36 AM   #1 (permalink)
Default Help Adsense ads not displaying
Hey friends,
I used to blog at http://techack.blogspot.com but ever since blogger updated itself to its new version (I know it was looong time ago), I tried adding adsense ads
I hv successfully added the ads throught Edit Layout feature but the ads are not displaying.
Can any1 plz help me with that?
I would be highly obliged
prabhatmohit is offline
Old 24-06-2008, 09:42 AM   #2 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Default Re: Help Adsense ads not displaying
I use Adblock Plus & Admuncher
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 24-06-2008, 10:30 AM   #3 (permalink)
Hey Ecko it seems u didn't get my problem.
The problem is that my blog isn't displaying google adsense ads but in adsense a/c impressions are increasing
One of my friend reported that he can see the ads...then why not me?
I m using Firefox and IE 7 both and no extension too block ads....plz help me
Last edited by prabhatmohit; 24-06-2008 at 10:42 AM. Reason: Automerged Doublepost
Old 24-06-2008, 10:45 AM   #4 (permalink)
Web developer
narangz's Avatar
I can see one ad on the left.
Are you using any firewall?
narangz is offline
Old 24-06-2008, 12:01 PM   #5 (permalink)
no...I m using XP SP2 (means that by default firewall is on)
Old 24-06-2008, 02:48 PM   #6 (permalink)
Web developer
narangz's Avatar
Is JavaScript enabled? If no, enable it. If it still doesn't display the ads follow these steps:
First, you may want to check your hosts file which is usually located at
C:\WINDOWS\system32\drivers\etc\hosts . Sometimes 3rd party software alters this file. If any of the following entries are present, please delete them.
# [Google Inc][Restricted Zone site]
127.0.0.1 adwords.google.com
127.0.0.1 pagead.googlesyndication.com
127.0.0.1 pagead2.googlesyndication.com
127.0.0.1 adservices.google.com
127.0.0.1 www.googleadservices.com
If this doesn't work, there is a chance you will need to re-register the following file in your computer's registry. To do so:
- Click Start -> Run
- Type in regsvr32 jscript.dll and press enter
Sometimes this file may prevent javascript from running properly in browsers.
narangz is offline
Old 28-06-2008, 01:18 PM   #7 (permalink)
None of abovr method work
Host file includes this::
# [Google Inc]
127.0.0.1 pagead2.googlesyndication.com #[Google AdWords]
127.0.0.1 video-stats.video.google.com
127.0.0.1 ssl.google-analytics.com #[urchinTracker]
127.0.0.1 www.google-analytics.com #[Google Analytics]
127.0.0.1 imageads.googleadservices.com #[Ewido.TrackingCookie.Googleadservices]
127.0.0.1 partner.googleadservices.com
should i remove any of the above lines?
Old 28-06-2008, 02:51 PM   #8 (permalink)
Web developer
narangz's Avatar
^^ Yeah remove every line which has google in it. You'll see the ads after you remove them
You'll have to delete all these lines. Delete them and save the file. A restart might be required.
# [Google Inc]
narangz is offline
Old 28-06-2008, 03:21 PM   #9 (permalink)
bajaj151's Avatar
Are you using kaspersky or any other antivirus ??
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline
Opera not displaying images Cool Buddy Software Q&A 1 12-05-2008 06:35 PM
Monitor not displaying guhanath Hardware Q&A 3 26-03-2008 05:42 PM
Adsense w.r.t Blospot versus Adsense w.r.t Website altimate QnA (read only) 12 12-01-2008 08:12 PM
Help Help Help Help! Images Not Displaying Shasanka_Gogoi Mobiles and Tablets 5 27-03-2007 10:17 PM
Yahoo Avatars not displaying raasm287 QnA (read only) 2 13-09-2005 05:18 PM
