Old 22-06-2008, 05:43 PM   #1 (permalink)
Default hiding a program
since i'm at hostel and i have to share my computer,i don't have privacy on my own's computer
so how can i install a program and still hide that program's name from "ADD OR REMOVE PROGRAM" category of control panel?
can anybody plz help me?
raj_kshetri is offline
Old 22-06-2008, 06:10 PM   #2 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Re: hiding a program
i hav de same prob
try "1st security agent" (u can restrict using this )
even "universal sheild" is a good protection soft
ankushkool is offline
Old 22-06-2008, 06:12 PM   #3 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
I don't know about this but is it not possible to you create guest accounts for them and define policies?
गीक होना माँगता
victor_rambo is offline
Old 22-06-2008, 06:20 PM   #4 (permalink)
hullap's Avatar
i got an idea,
maybe u can install the program, copy the folder(the install directly, like C:/program file/BLAH BLAH) and then uninstall it,
then try to run the executable,
then u can use any encrypter to hide it
Hope This Helps
hullap is offline
Old 30-06-2008, 12:49 PM   #5 (permalink)
hey the tip from ANKUSHKOOL was quite helpful.
i downloaded "1st seucrity agent" n it has the exact function as i needed.
so thanks a lot.
but ya how can i hide the "1st security agent's" folder from program files section because i share ADMINISTRATOR account with my frens.is there any way out?
Old 01-07-2008, 12:11 PM   #6 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
Arre yaar use Regedit and then goto Hkey_Local_Machine >>Software >>Microsoft>>Windows>>Current Version>>Uninstall and then click on the "+" icon on it to reveal further "blah blah" type names, from there click on each sub-folder and select the name of the software from the right hand side and when you have found what you have to hide then delete the sub-Key, and there's it ! Voila ! But please note that it does not affect the software rather only hides it from Add or Remove Programs, you can always uninstall it by going to the Program Files folder and executing the uninstaller of that software
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
hiding folder patelviren QnA (read only) 1 17-07-2007 08:50 PM
Hiding Folder 047 Software Q&A 12 18-04-2007 05:35 PM
Tip for hiding Drives Gurpreet Kaur Tutorials 10 30-01-2006 10:47 AM
Hiding a folder Gaurav QnA (read only) 3 26-07-2005 01:33 PM
new program in 'close program menu' list and more....... vishakadatta QnA (read only) 2 12-04-2005 11:33 PM
