Old 21-06-2008, 10:28 AM   #1 (permalink)
hansraj's Avatar
Default Is my memory module a bottleneck???
Guys my laptop has the configuration which is as attached as the cpu-z file. now i want to know that is my bottleneck my memory module??? coz it shows the frequency of 266 Mhz whereas the chipset is capable of 532( Plz correct me if i have understood it wrong). The reason i am asking this is i am planning to upgrade my ram to 2 GB or more but i think removing the existing module and upgrading with both new memory modules with 533 Mhz should be better, thats what i think. Whats the experts opinion.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 21-06-2008, 01:50 PM   #2 (permalink)
slugger's Avatar
Default Re: Is my memory module a bottleneck???
AFAIK a 266 MHz DDR is runnin at 532
dats y its called DDR
slugger is offline
Old 21-06-2008, 09:00 PM   #3 (permalink)
hansraj's Avatar
So does it mean the chipset is capable of 266 Mhz memory modules only!!!
hansraj is offline
Old 22-06-2008, 10:45 AM   #4 (permalink)
slugger's Avatar
ur mobo had specified the nominal clock speed it supports
for DDR RAMs real clock speed is haf of nominal clock speed..its working at its supported speed. gettin a higher clock speed RAM will only make it run at the supported speed
slugger is offline
rig on which 8800gt will not bottleneck !! allmighty Hardware Q&A 4 19-12-2007 06:42 PM
cpu fsb bottleneck slyfox Hardware Q&A 13 01-07-2007 05:12 PM
BottleNeck????? assasin Hardware Q&A 2 02-06-2007 10:09 PM
will this have a bottleneck performace? vineeth_pulari Hardware Q&A 2 16-11-2006 11:39 PM
Is dere a BOTTLENECK in My PC assasin Hardware Q&A 7 06-11-2006 08:43 AM
